0 members (), 136 guests, and 2 robots.
Topics128,035
Posts1,055,560
#21178 10/03/2004 12:35 AM
Junior Member
Junior Member
I recently installed a 58' 261 into my 55' 1st series 3100. The fan blades look like they will go into the radiator. Is there a shorter water pump shaft or is there a differnce in fans from the original engine and the 261. The 261 came out of a larger truck, I think it was a (viking). Not exactly sure of the model but it was a 58'.
Kevin & Cindy
#21179 10/03/2004 2:54 AM
It's a common problem that now has an easy fix. Several vendors sell modified water pumps with a shorter shaft. We used to have to do them ourselves. You still can if you can find a 292 Ford pulley.
#21180 10/03/2004 3:21 AM
Junior Member
Junior Member
Thanks for the help. Now the silly question. What size engine came in the 55 1st series, 3100?
Kevin & Cindy
#21181 10/03/2004 3:47 PM
Junior Member
Junior Member
What vendors have this style water pump?
Kevin & Cindy
#21182 10/03/2004 7:21 PM
55.1 came with a 235.
Buzz'n Half Dozen
#21183 10/04/2004 9:26 AM
Quote
Chevs of the 40es or Patriks
