| | | Forums66 Topics128,057 Posts1,055,810 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 313 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 313 | When I fill my 1966 C-10, it tends to splash gasoline. In fact every one of the three 1966 Chevrolet Pick-ups that I have owned has done the same thing. I suppose that the problem has to do with the short filler neck. Is there any solution to this annoying problem, or do I have to deal with it? | | | | | Joined: Nov 2005 Posts: 266 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 266 | If yours splashes gas out of the filler neck like mine does, don't pump quite as fast and stick the nozel as far into the filler neck as you can. I did that and now it doesn't splash anymore. It takes longer to fill up, but it all goes into the tank where it belongs. Hope that helps, Drew | | | | | Joined: Aug 2004 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 141 | Doug,
Improve the air return flow from your tank. | | |
