0 members (), 93 guests, and 1 robot.
Topics128,055
Posts1,055,782
When I fill my 1966 C-10, it tends to splash gasoline. In fact every one of the three 1966 Chevrolet Pick-ups that I have owned has done the same thing. I suppose that the problem has to do with the short filler neck. Is there any solution to this annoying problem, or do I have to deal with it?
If yours splashes gas out of the filler neck like mine does, don't pump quite as fast and stick the nozel as far into the filler neck as you can. I did that and now it doesn't splash anymore. It takes longer to fill up, but it all goes into the tank where it belongs. Hope that helps, Drew
Doug,
Improve the air return flow from your tank.
