2 members (Hotrod Lincoln, KCMongo), 59 guests, and 1 robot.
Topics128,050
Posts1,055,639
#211424 07/09/2006 11:44 PM
Ok, where is a good place to buy heater cores for a 49 3600 with the "fresh air" heater unit. (The heater with the blower motor sticking out of the firewall) I've seen them for $150 somewhere, but that seems extremely overpriced.
#211425 07/09/2006 11:51 PM
I had the local radiator shop build mine.
1951 3100 Chevrolet
#211426 07/10/2006 1:47 AM
They are overpriced. Apparently that size core is only made by one factory. But a radiator shop should be able to help.
#211427 07/10/2006 3:37 AM
I could'nt locate a good nos or remanufactured.I paid $100.00 for mine in 1990.That was the best price at the time. They are a little pricey,but you gatta have a heater.
1951 3100 Chevrolet
#211428 07/10/2006 3:48 AM
now and then see a few on eBay
#211429 07/10/2006 7:08 AM
I had my 72 heater core redone at the radiator shop for $50. Try them first.
#211430 07/10/2006 9:58 PM
I've had an old radiator repair man check mine out- he can't fix it.
#211431 07/10/2006 10:11 PM
Unless it is the round type which I do not think it is you should be able to have it recored for less then $100.00.
Good Luck
Steve
#211432 07/10/2006 10:20 PM
You might want to check out the salvage yards to see if can find a better core. The heater in my '55 was built completely from salvaged parts, exept for the control valve.
Bill Burmeister
#211433 07/10/2006 10:21 PM
I took a couple to an old timey raditor man, he was able to boilout & repair both, 30.00 ea.& looked like new.
#211434 07/10/2006 10:27 PM
A good radiator shop should be able to find the new core for you, and then he will take the tanks off the old one and put them on the new one. I do not think it is a good idea to look for a used core in the junk yard, you will more than likely be right back where you started from really soon.
#211435 07/11/2006 1:33 AM
Brian, I have never seen one of these heaters with a "TANK"? The water goes to and from the heater coil via the cooling system.
#211436 07/11/2006 2:13 AM
There isn't a "tank" on a typical heater core. And as far as getting one from a salvage yard goes, I got mine from a salvage yard and it was ok. It would cost less than having the rad shop get one that would probably be as much or more than the aftermarket one (cuz you know he'll mark it up). You can find good cores for about $10-$25. I got the entire heater for only $60, and that was the Deluxe heater.
Bill Burmeister
#211437 07/11/2006 3:30 AM
I want to say that the radiator shop used my original copper lines on the new core.I can't remember,suffering from "CRS"!!!
1951 3100 Chevrolet
