4 members (1955 1 Series, Otto Skorzeny, DaveV, Southerntruck), 78 guests, and 0 robots.
Topics128,115
Posts1,056,294
Members48,439
I bought a 235 and put it in my truck. It was supose to have a bellhousing that bolted up to my transmission. It turns out that it fit a 69 chevy four speed. I bougt a driveline out of a 3/4 ton 69 chevy however it was about two inches too long. I was wondering if there happens to be a drive line that is a perfict fit?
Let's be sure we have this right. You have a Chevy truck (year?) in which you have installed a 235 and a SM465 tranny from a 69. I'm assuming your truck is a 3/4 ton. If your driveshaft will work, except for being too long, I would recommend you find a local driveshaft shop and have them cut, weld and balance your shaft.
Fred
52 3600
69 C-10
I have a 3\4 ton 1947. I took the front half of the driveshaft to a shop and they cut it for me.
