| | | Forums66 Topics128,196 Posts1,057,395 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 101 Member | | Member Joined: Dec 2005 Posts: 101 | Hey Guys,
What would be the best complete chassis swap for 1955 chevy 2nd series. Would as S-10 chassis fit under without much work?
Roger http://www.flickr.com/photos/45469713@N00/?saved=1
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The track width on an S-10 is too narrow to look right under a '55. A '73-'87 chassis fullsize would be better, I would think. You could also adapt the front crossmember from a '73-'87 if you want to get the suspension upgrade, that'll save you from having to adapt the body to fit a different frame.
Bill Burmeister | | |
