3 members (klhansen, ronsway, 1 invisible),
165
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,106 Posts1,056,213 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I scored a 98 Mercury marquis electric fan setup from the local U-Pull-It for $25. When I got home I was amazed-it is nearly a bolt in for the big six/V8 radiator!(24",not the tiny 17" small six radiator) I cut off the OE mounting tabs w/a sabre saw, & it slips in place of the OE shroud, just need to drill the attaching holes & wire it up. these fans pull an honest 3000 CFM + & draw about 30-40 amps. brian web page | | | | | Joined: Jun 2006 Posts: 41 Member | | Member Joined: Jun 2006 Posts: 41 | Wow, looks great! I should try that on my C20, as it doesn't have the factory shroud anymore and it tends to overheat. What's involved with wiring it? Do you set it to run all the time?
Get some good information or help? Donate to the site and keep it alive for all to enjoy!
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | you can, you will need a heavy switch or relay(preferred),,I haven't wired it yet but it has 2 speeds. Moves enough air to spin the cluch fan on an engine/trans sitting in the floor a couple feet away!(shop is a mess) I plan on low speed coming on @ operating temp, then the high speed when a/c is on. Several websites have info on wiring, usually the Ford taurus/Merc Sable fan are used. the Crown/Marquis is the same fan w/a different shroud which happens to fit like it was made for the 64. brian | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I bought a after market temp controled switch. works as both a relay and switch (about 25 bucks.) 40amps is too much not to use a relay. I don't know of a switch that will hold it. | | | | | Joined: Jun 2006 Posts: 41 Member | | Member Joined: Jun 2006 Posts: 41 | Great deal, I'll go that way. Thanks a lot!
