4 members (KEVINSKI, DadsFirstPickup, Hanks custodian, Ponchogl), 198 guests, and 1 robot.
Topics128,108
Posts1,056,230
Members48,436
#211341 07/07/2006 4:17 PM
I scored a 98 Mercury marquis electric fan setup from the local U-Pull-It for $25. When I got home I was amazed-it is nearly a bolt in for the big six/V8 radiator!(24",not the tiny 17" small six radiator) I cut off the OE mounting tabs w/a sabre saw, & it slips in place of the OE shroud, just need to drill the attaching holes & wire it up. these fans pull an honest 3000 CFM + & draw about 30-40 amps. brian web page
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#211342 07/07/2006 5:46 PM
1 Offline
Wow, looks great! I should try that on my C20, as it doesn't have the factory shroud anymore and it tends to overheat. What's involved with wiring it? Do you set it to run all the time?
Get some good information or help? Donate to the site and keep it alive for all to enjoy!
#211343 07/07/2006 5:54 PM
you can, you will need a heavy switch or relay(preferred),,I haven't wired it yet but it has 2 speeds. Moves enough air to spin the cluch fan on an engine/trans sitting in the floor a couple feet away!(shop is a mess) I plan on low speed coming on @ operating temp, then the high speed when a/c is on. Several websites have info on wiring, usually the Ford taurus/Merc Sable fan are used. the Crown/Marquis is the same fan w/a different shroud which happens to fit like it was made for the 64. brian
#211344 07/07/2006 6:09 PM
I bought a after market temp controled switch. works as both a relay and switch (about 25 bucks.) 40amps is too much not to use a relay. I don't know of a switch that will hold it.
#211345 07/08/2006 2:01 AM
1 Offline
Great deal, I'll go that way. Thanks a lot! smile
