0 members (),
85
0
Mod | | | Forums66 Topics128,115 Posts1,056,291 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 39 Member | | Member Joined: Oct 2004 Posts: 39 | I bought a 235 and put it in my truck. It was supose to have a bellhousing that bolted up to my transmission. It turns out that it fit a 69 chevy four speed. I bougt a driveline out of a 3/4 ton 69 chevy however it was about two inches too long. I was wondering if there happens to be a drive line that is a perfict fit? | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Let's be sure we have this right. You have a Chevy truck (year?) in which you have installed a 235 and a SM465 tranny from a 69. I'm assuming your truck is a 3/4 ton. If your driveshaft will work, except for being too long, I would recommend you find a local driveshaft shop and have them cut, weld and balance your shaft.
Fred 52 3600 69 C-10
| | | | | Joined: Oct 2004 Posts: 39 Member | | Member Joined: Oct 2004 Posts: 39 | I have a 3\4 ton 1947. I took the front half of the driveshaft to a shop and they cut it for me. | | |
