| | | Forums66 Topics128,135 Posts1,056,422 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#2108 11/07/2003 12:18 AM | Joined: Nov 2003 Posts: 6 Junior Member | | Junior Member Joined: Nov 2003 Posts: 6 | Can someone tell me how to tell what engine I have. I bought my 2nd 53 chevy 1/2 ton recently and the other block from my other truck was set up differently. I found out that the engine and transmission were used 55-59 or something so did they use the bigger engines for those years or what. My guess is that its a 235, but who knows. I am pretty sure that the other block I have is a 216. thanks | | |
#2109 11/07/2003 12:31 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Find your block casting number and compare it to the casting number chart at Inliners International. | | | | | Joined: Nov 2003 Posts: 1 Junior Member | | Junior Member Joined: Nov 2003 Posts: 1 | Where would I look for a block casting number? | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Just behind the starter on the side of the block, startswith CON4 or something like that
