| | | Forums66 Topics128,050 Posts1,055,759 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#21073 03/09/2003 4:03 AM | Joined: Feb 2001 Posts: 3 New Guy | | New Guy Joined: Feb 2001 Posts: 3 | This is one I haven't heard discussed. I made a tail shaft extension from a donor 70's 3 speed and machined a tail shaft housing from 6" x 10" round cold roll(weighed 70 lbs when I started and 18 when finished), fabricated a rear mount and installed and S10 rear end. End result, original tranny, 3:73 ratio so the driving experience is still there but 55 is a reality. It all ready has one summers use on it with no problems.
38 Chevy 1/2 ton
#21074 03/10/2003 12:18 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Sounds quite interesting. Do you have pics and or more details?
#21075 03/10/2003 8:09 PM | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | and what's that in, again? You replaced your torque-tube with this mod? Details, please.
Professional Novice
#21076 03/11/2003 11:58 PM | Joined: Feb 2001 Posts: 3 New Guy | | New Guy Joined: Feb 2001 Posts: 3 | sorry about the delay in replying. I took pictures every step then learned a valuable lesson about letting my darling wife load film in the camera. The donor transmission gave up the tailshaft so I would have the splines to match the new driveshaft. The otherend of this roughly 9" piece had a spline machine on it to match the old universal joint so I could leave it in place for the speedo drive. These were pinned together and a housing machined with a bushing in the front to carry the old universal joint(of course it doesn't universal anymore) and a standard chevy bushing and seal in the rear for the new driveshaft. Stock 38 tranmission with new open drive line. If you want to consider doing this email me and I'll sketch it up with dims.
38 Chevy 1/2 ton
#21077 03/12/2003 1:28 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | hseber, so you still use the vintage tranny, with an adapted tailhousing so you can use an open drivline, correct? If so,back in the late 50's before good floorshift kits like Hurst, hot rodders used the top shifting old tranny cases like your,adapted the 55 and up tailhousing from a Chevy 3 spd for use in open driveline cars.I belive the mainshaft from a 55 and up Muncie 3spd will more or less fit into the older transmissions.it might require some machine work.Its great to hear some guys like you are still daring to be different. | | |
