4 members (dogdaddy, Ponchogl, 2-Ton, 1 invisible), 72 guests, and 2 robots.
Topics128,037
Posts1,055,463
Members48,422
#210653 06/26/2006 7:09 PM
Hi Everybody,
I've got what should be a simple question. I have a 59 3/4 ton that I would like to convert to a short wheelbase 1/2 ton by swapping the body over to another chassis. I'm assuming the chassis from any year Task Force 55 2nd through 59 should work. Am I correct?
Thanks, John
#210654 06/26/2006 8:47 PM
sort of - the only difference is the 58/9 frame is about 2" longer than the 55-7 at the front because of the gravel pan right behind the bumper, so your front sheet metal will stick out too far to use the normal bumper brackets - I put a 57 front on a 58 frame and this shows how much had to be cut off - you hafta add on that much
#210655 06/27/2006 2:32 PM
Thanks Bill, exactly what I needed to know. John
