1 members (Phak1),
65
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,022 Posts1,055,361 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 128 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 128 | Hi Everybody, I've got what should be a simple question. I have a 59 3/4 ton that I would like to convert to a short wheelbase 1/2 ton by swapping the body over to another chassis. I'm assuming the chassis from any year Task Force 55 2nd through 59 should work. Am I correct?
Thanks, John | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | sort of - the only difference is the 58/9 frame is about 2" longer than the 55-7 at the front because of the gravel pan right behind the bumper, so your front sheet metal will stick out too far to use the normal bumper brackets - I put a 57 front on a 58 frame and this shows how much had to be cut off - you hafta add on that much Bill | | | | | Joined: Oct 2004 Posts: 128 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 128 | Thanks Bill, exactly what I needed to know. John | | |
