0 members (), 97 guests, and 0 robots.
Topics128,049
Posts1,055,680
#210346 06/21/2006 9:45 PM
Junior Member
Junior Member
I am having problems aligning the hood on my 54' chevy pick. any suggestions?
#210347 06/21/2006 10:42 PM
When you find out let me know I have been trying for two weeks on my 51. PLEASE!!!!
#210348 06/22/2006 12:28 AM
Ex Hall Monitor
Ex Hall Monitor
Need more info. Does it line up anywhere? What have you tried so far? Have you replaced any sheetmetal? Is the core support straight? Are you having trouble lining it up to the striker or to a fender or both fenders or to the cowl or is it sitting too high in the back or is it not sitting high enough in the back or is it sitting to low in the front or too high in the front. You help us & we'll help you. Guys this isn't a one size fits all problem. I've aligned a lot of doors, fenders & hoods over the years and I'd love to try to help you but I need to know where to start. wink
#210349 06/22/2006 2:09 AM
I have a 1951 1/2ton Cowl lines up fenders to hood line up, but the hood spring bolt wont line up with the hood latch, it is a good inch off. The hood is also way too close to the top bar of the grille
#210350 06/22/2006 2:55 AM
Anonymous
Unregistered
Anonymous
Unregistered
my front support had spacers between it and the frame,I took pics when I removed it just incase.
http://community.webshots.com/mypho...mp;albumID=551574341&security=flvVnp
#210352 06/22/2006 3:02 PM
Just my 2 cents and you guy's probably used the same bolts anyhow. Had the same problem. That is when I found out the bolts for the hood are designed for the hood. Other bolts even though they look similar will not work or at least wouldn't in my case. I thought I would be smart and put shiny new bolts on in place of the old ones.
#210353 06/22/2006 3:11 PM
Ex Hall Monitor
Ex Hall Monitor
Quote
Originally posted by TooMany2count:
hood alignment page ....joe
Excellent resource Joe. grin
#210354 06/22/2006 3:55 PM
Anonymous
Unregistered
Anonymous
Unregistered
Kdrown,that's true.I just took off my front clip and noticed the bolts had an enlarged smooth section near the head.I think using fully threaded bolts would cause it to tighten and/or loosen whenever opening the hood.pics here
http://community.webshots.com/photo/551424330/2283787320092821122EsDaBE
#210355 06/22/2006 5:11 PM
There have been a lot of threads on this subject The hood alignment is the bane of AD owners. Look at old original pictures of these trucks and some of the finest show rigs out there and the hood alignment is not perfect. I loved one person's comment here, "This is why I always show my truck with the hood up." Read the instructions, find some patience and spend some lengthly quality time with your truck. At some point I think most folks get to "good enough."
1950 Chevy 3100
261, 4 speed
Purchased 1977
1964 Pontiac Lemans Convert
#210356 06/22/2006 8:19 PM
If the instructions from the hood alignment page work,Joe I owe you a beer or your beverage of choice. I will try this weekend and post my progress. Thanks Paul
