1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 3 Junior Member | | Junior Member Joined: Jun 2006 Posts: 3 | I am having problems aligning the hood on my 54' chevy pick. any suggestions? | | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | When you find out let me know I have been trying for two weeks on my 51. PLEASE!!!! | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Need more info. Does it line up anywhere? What have you tried so far? Have you replaced any sheetmetal? Is the core support straight? Are you having trouble lining it up to the striker or to a fender or both fenders or to the cowl or is it sitting too high in the back or is it not sitting high enough in the back or is it sitting to low in the front or too high in the front. You help us & we'll help you. Guys this isn't a one size fits all problem. I've aligned a lot of doors, fenders & hoods over the years and I'd love to try to help you but I need to know where to start.
| | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | I have a 1951 1/2ton Cowl lines up fenders to hood line up, but the hood spring bolt wont line up with the hood latch, it is a good inch off. The hood is also way too close to the top bar of the grille | | | | | Joined: May 2004 Posts: 76 'Bolter | | 'Bolter Joined: May 2004 Posts: 76 | Just my 2 cents and you guy's probably used the same bolts anyhow. Had the same problem. That is when I found out the bolts for the hood are designed for the hood. Other bolts even though they look similar will not work or at least wouldn't in my case. I thought I would be smart and put shiny new bolts on in place of the old ones. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Excellent resource Joe.
| | | | | Joined: Jan 2004 Posts: 223 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 223 | There have been a lot of threads on this subject The hood alignment is the bane of AD owners. Look at old original pictures of these trucks and some of the finest show rigs out there and the hood alignment is not perfect. I loved one person's comment here, "This is why I always show my truck with the hood up." Read the instructions, find some patience and spend some lengthly quality time with your truck. At some point I think most folks get to "good enough." | | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | If the instructions from the hood alignment page work,Joe I owe you a beer or your beverage of choice. I will try this weekend and post my progress. Thanks Paul | | |
