3 members (Hotrod Lincoln, MickeyP, Brian Moore), 44 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#210274 06/20/2006 4:28 AM
I was just going to try to lift my truck for the first time. I am using a 2-post lift and discovered I need extensions to clear teh running boards, but that is another subject.
I also noticed that the rear eye of both front springs is busted. The front shackles have swung full forward and the rear of the springs are setting against the front of the shakle mount. If I try to lift the truck, the whole front suspension is going to want to rotate forward. Has anybody ever had this dilema? Any ideas?
I had planned on installing an IFS at a later date, but it looks more and more like I am going to have to skip past the drive it as is phase and move right into the tear it apart and fix it right phase. :rolleyes:
#210275 06/20/2006 5:09 PM
What year truck do you have?I have replaced the front and rear suspension on my 55 2nd and have 4 good stock springs
#210276 06/21/2006 7:44 PM
My truck is a 1951 3100
#210277 06/21/2006 8:29 PM
If you are just going to roll the truck around your shop until you put in the IFS I wouldn't worry about it. If you plan on driving it you must do something about those springs.
You can go to a spring shop and have the main spring replaced and the remainders rearched for 200+ dollars.
You could find a set used on this site or elsewhere. Lots of people are installing IFS and getting rid of their old springs.
I'm sure someone will come up with some other options.
#210278 06/21/2006 8:35 PM
Not to get off topic, but can you blast and paint the springs with a truck bedliner or is it better to just paint them with paint?
Get busy liv'n or get busy die'n
#210279 06/21/2006 10:41 PM
Chazwel,I would use a good rattle can paint.Todd M,I have a good set of front springs I will sell you if you want.Drop me a PM and let me know.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#210280 06/22/2006 6:06 PM
Just weld them and anneal them, till you've got the time and money for new ones,google annealing metals.
