7 members (MRMEROTH11, TUTS 59, Barney1951, Gray_Ghost, Wickedbass, JW51, walter74),
96
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,068 Posts1,055,880 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | Is there a place to find out what your serial no.'s in Canada mean?My no.'s don't seem the same as USA,I have a 1300 ,1953 1/2 ton. | | | | | Joined: Jun 2002 Posts: 179 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 179 |
When I go cruisin' in the old truck....women smile, men weep and dogs beg for rides.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | and you won't find out much besides what ya already know! the 1300 series is the CDN version of the 3100 - a short 1/2T, the last part of the number is the line sequence number [serial #] - also for 53 the number will most likely be the engine #, and you can count on it having been built in Oshawa
Bill | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | KillerNight, go to this GMC site: http://www.oldgmctrucks.com/ On there somewhere is a chart for Canadian trucks. The difference with the GMC series is where you have a 1300, the GMC series would be 9300. I used this site to determine exactly what my 51 was. I think that it does go up to 53 but I am not positive. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Lothar - on my 49 the number is 91314XXXX. 9 being the year (49) 13 being half ton, 14 a pick up and the next numbers are serial. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | KNight, here is the link to the Canadian GMC serial numbers. I think that you will find similarities to the Chevy numbers. http://www.oldgmctrucks.com/page0185.html | | |
