1 members (baldeagle),
34
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | well got my glass for my two trucks from lmc all 4 windshields were broke and one back window has two chips in the edge should i try to sand the chips smooth or just install and hope it dosent crack or tell them i want another one im hoping the answer is sand the chip out or leave it alone what would you do they did a bad job of packaging the glass i hated seeing all that new glass all cracked up im wondering if i could take them to a local shop and have some wing windows cut from the broken peaces | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I would call the vendor and ask them how they want to resolve the problem first. The steps after that would depend on their answer. FYI, I'm not being critical but I had to read your post several times to get what you were trying to say. Punctuation helps the reader to understand your point.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Do not try to use any glass with a chip in the edge. There is close to a 100% chance that a crack will eventually start from an edge-chip.
I have received many curved windshields and flat pieces of glass from several vendors. They all arrived safely. LMC is a good company and they should be able to do better. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | did they come that way?? send them BACK place a UPS/USPS claim get that #
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | Call the vendor first, they may not want to pay to ship the broken stuff back.
| | | | | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | 32fire2 Check a local glass maker.I saved a lot of $$.Took the old ones for pattern and wa,,la,perfict match,excep when I put my out side sun visor on with the clamp around the center bar(crack 1 1/2 " long but looks origional) will replace this winter.
53 chevy 3100 pickup 12 years in restoration | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | The chip has to be pretty bad for it to crack. If you don't want to hassel with returning, take them to a local glass shop and have them wet grind the 2 spots.
I agree with beaver, a local can do it cheaper and better. LMC has a local shop do their's. So your cutting out the middle man.
wilbur | | |
