3 members (Tstan7, Gone, Napco Mark), 125 guests, and 6 robots.
Topics128,022
Posts1,055,353
Members48,420
#210085 06/16/2006 10:35 AM
well got my glass for my two trucks from lmc all 4 windshields were broke and one back window has two chips in the edge should i try to sand the chips smooth or just install and hope it dosent crack or tell them i want another one im hoping the answer is sand the chip out or leave it alone what would you do they did a bad job of packaging the glass i hated seeing all that new glass all cracked up im wondering if i could take them to a local shop and have some wing windows cut from the broken peaces
#210086 06/16/2006 1:52 PM
Ex Hall Monitor
Ex Hall Monitor
I would call the vendor and ask them how they want to resolve the problem first. The steps after that would depend on their answer.
FYI, I'm not being critical but I had to read your post several times to get what you were trying to say. Punctuation helps the reader to understand your point. smile
#210087 06/16/2006 2:04 PM
Do not try to use any glass with a chip in the edge. There is close to a 100% chance that a crack will eventually start from an edge-chip.
I have received many curved windshields and flat pieces of glass from several vendors. They all arrived safely. LMC is a good company and they should be able to do better.
#210088 06/16/2006 2:53 PM
did they come that way??
send them BACK
place a UPS/USPS claim
get that #
Jim & Caroline
#210089 06/16/2006 6:12 PM
Call the vendor first, they may not want to pay to ship the broken stuff back.
#210090 06/16/2006 9:26 PM
32fire2 Check a local glass maker.I saved a lot of $$.Took the old ones for pattern and wa,,la,perfict match,excep when I put my out side sun visor on with the clamp around the center bar(crack 1 1/2 " long but looks origional) will replace this winter.
53 chevy 3100 pickup 12 years in restoration
#210091 06/16/2006 10:15 PM
The chip has to be pretty bad for it to crack.
If you don't want to hassel with returning, take them to a local glass shop and have them wet grind the 2 spots.
I agree with beaver, a local can do it cheaper and better. LMC has a local shop do their's. So your cutting out the middle man.
wilbur
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
