0 members (), 254 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
#209846 06/12/2006 10:27 PM
I have the opportunity to rape and pilage a '79 Chevy pickup for anything I want for $250. A guy I know gave it to his kid who promptly rolled it. Obviously the engine runs (it was apparently running pretty fast when the wheels left the ground and skidded down the road on its top). I'm thinking of replacing the 230 in my 63 with the 350 from the '79. I'm thinking power brake system, front spindles and engine. Tranny is an automatic that I'm not interested in. What else should I take? The guy is going to haul whatever is left to the junk yard when I'm done.
Daily Driver 63 C-10 LWB Fleetside
Riding in the Passing Lane
Get the power steering gear. It is easy to install on that model. Get everything that goes with the engine. Brackets, pulleys, str.pump & a/c comp if equipt.
1972 Chevy c10 Cheyenne Super
Get the rear axle too. That way you can change to 5 lug all around.
Bill Burmeister
Thanks guys!
Grab the trans. If nothing else, you can put it in the local classifieds for $99 and give somebody a great deal, while getting back some money.
Get the wheels and tires. Battery (especially if it's new)
-Brad
SOUTHERN FALL GABfest
October 6 ~ Commerce, Georgia
Details here!
Never Pee on an Electric Fence.
See if the guy will give you the title and then take the whole thing to your house to pull parts off of until you are done with it, then send the carcass to the boneyard.
I would dearly love to take it home to pilfer at my leisure...however, I live in a neighborhood where the city has taken over the duties normally associated with home owner's associations. They have ordinances against that sort of thing so I have to strip it in his field and then help him load the carcass on a trailer to haul off.
