| | | Forums66 Topics128,077 Posts1,056,015 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | I have the opportunity to rape and pilage a '79 Chevy pickup for anything I want for $250. A guy I know gave it to his kid who promptly rolled it. Obviously the engine runs (it was apparently running pretty fast when the wheels left the ground and skidded down the road on its top). I'm thinking of replacing the 230 in my 63 with the 350 from the '79. I'm thinking power brake system, front spindles and engine. Tranny is an automatic that I'm not interested in. What else should I take? The guy is going to haul whatever is left to the junk yard when I'm done. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Get the power steering gear. It is easy to install on that model. Get everything that goes with the engine. Brackets, pulleys, str.pump & a/c comp if equipt. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Get the rear axle too. That way you can change to 5 lug all around.
Bill Burmeister | | | | | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | | | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | Grab the trans. If nothing else, you can put it in the local classifieds for $99 and give somebody a great deal, while getting back some money.
Get the wheels and tires. Battery (especially if it's new)
-Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | See if the guy will give you the title and then take the whole thing to your house to pull parts off of until you are done with it, then send the carcass to the boneyard.
| | | | | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | I would dearly love to take it home to pilfer at my leisure...however, I live in a neighborhood where the city has taken over the duties normally associated with home owner's associations. They have ordinances against that sort of thing so I have to strip it in his field and then help him load the carcass on a trailer to haul off. | | |
