| | | Forums66 Topics128,154 Posts1,056,855 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#20982 03/31/2002 5:15 PM | Joined: Jun 2000 Posts: 3 Junior Member | | Junior Member Joined: Jun 2000 Posts: 3 | Looks like a rear main seal leak but I have replaced the seal twice and it continues to leak badly! I know these things always leak a little but.....man this is pretty bad. Can't find anyone who really knows what to do. Thanks for some advice. | | |
#20983 03/31/2002 6:26 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | Hank, I have scanned a picture from the shop manual, take a look at it. There are two plugs in the rear of your engine that could leak oil, a pipe plug and a camshaft bearing plug. Oil coming from either of them would leak to the rear of your motor and make it seem like the rear main was leaking. Also reach around the back of the head and make sure that the valve cover gasket is not leaking. Unless I glue my gasket to the valve cover I have trouble with a leak in that area. I hope this helps.. Plugs at rear of motor
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#20984 03/31/2002 7:40 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | The new replacement rope seals are of inferior quality to the old ones containing asbestos fibers.The new seals are especially prone to leak if you have replaced the seal halves without pulling the crankshaft.Forcing the upper seal into place ,stretches the fibers, and promotes leaks.On the Stovebolt links are several vendors who sell NOS asbestos seals.I don't like to recomend certain vendors but I believe Stovebolt Engine Co. has them.You may have better luck with the NOS seal. But like Bill says, make sure its the seal that leaking. | | |
