4 members (Gray_Ghost, Woodcmiami, GMCJammer51, Paul_WNC), 109 guests, and 3 robots.
Topics128,050
Posts1,055,753
#209148 06/06/2006 2:48 PM
My poor doors need new weather stripping big time. I assume the only way to do it is to remove the doors?
....and of course I assume the best adhesive is still:
[img]http://cmaynard.com/Misc/gorillasnota.jpg[/img]
Craig
#209149 06/06/2006 6:03 PM
I did mine with the doors on. A little tricky around the hinges but doable. I used black 3M Super Weatherstrip Adhesive from my FLAPS.
#209150 06/06/2006 8:02 PM
Ex Hall Monitor
Ex Hall Monitor
Doors on is normally the way. The key word is clean. Make sure the door jamb is clean enough to eat off of. Hurried prep is the prime cause of adhesive failure.
#209151 06/06/2006 9:56 PM
I read in another thread the the 3m stuff is preferrable over the gorilla glue 'cause the GG expands when it dries.
#209152 06/07/2006 2:21 AM
Actually to clarify matters, I was referring to 3m's 08001 in yellow which almost everyone agrees is the best. I also learned that the yellow stuff is more durable than the black counterpart.
The W/S's normally arrive in a cut length. Is the W/S formed so that you must start your new W/S in a particular location around the door?
Craig
#209153 06/07/2006 2:58 PM
Junior Member
Junior Member
Alan H. has a very good article on replacing the door weatherstrip.
Replacing door weatherstrip
