5 members (Randy Baumann, TexasJim50, 52Carl, dt235sd, 1955 1 Series), 77 guests, and 5 robots.
Topics128,014
Posts1,055,324
Members48,419
#209088 06/05/2006 6:57 PM
hey guys. my truck is too squeaky! 63 c10. every little bump in the road and something is squeaking like crazy. I properly mounted my bed (PO had the bed mounted to fram with in 1 spot at read drivers side only eek ) that cut down on the noise but still getting a lot. I have new cab mounts and will get those replaced on evening this week but what are some other places i can check for squeaks? it sounds like something inside at the firewall or dash but i can't seem to find it. Any ideas?
#209089 06/05/2006 7:39 PM
Have you greased all of your zerks? Mine squeeked and creaked until I did that.
You may have to clean out the fittings, but it should just go in.
#209090 06/05/2006 7:59 PM
Also check your shocks & bushings.
#209091 06/05/2006 9:22 PM
Hose everything with WD-40 or a silicone spray.
Another quality post.
Real Trucks Rattle
#209092 06/06/2006 7:24 PM
good suggestions guys. thanks
