6 members (Robert Crandall, Hotrod Lincoln, 3800GUY, JW51, Wally / Montana, 1 invisible), 78 guests, and 2 robots.
Topics128,082
Posts1,055,961
Members48,430
Hi,
Easy one for you guys -- In the early V8 years where the front motor mount was a U shaped bracket that fastened to the front crossmember, did v8 trucks come from the factory with the I6 motor mounting point rivetted to the crossmember too, or was that omitted on v8s?
I'm preparing the front crossmember of my truck. I've got 2 crossmembers, but both were from original I6s.
Brian
no U shaped mount - the early V8s [TF years] had mounts that riveted on the cross member on each side near the original 235 mount points [the larger hole in the cross member in that pic], and the pegs were attached to the front of the motor - the V8 mounts were only put on if the truck was getting a V8 - by 60, they used the side mounting points on the V8, well behind the front cross member, which should still have the holes in it for the 235 mounting points
Red,
Sorry, I guess I should have been more specific. I'm talking specifically about on my '60. My v8 is mounted to a U shaped bracket at the front of the engine.
Brian
Any ideas?
