4 members (Steelonsteel, Hotrod Lincoln, 3800GUY, Barry Martak), 115 guests, and 1 robot.
Topics128,113
Posts1,056,613
Members48,450
#20894 01/15/2002 6:58 PM
In a few months I will be helping a friend install a 472 caddy engine and a TH400 tranny in a 71 chevy pick-up.
Does anyone know if this will bolt in?
I know there will be several items to be rearranged and fabricated.I just want to go into this project with a few extra brain-cells!
(I only have two,,,one in the middle and one circling the one in the middle saying"I work alone!,,,,,I work alone!)
Anyone willing to donate?
there are some guys that have done the 500 swaps over at coloradok5.com... you might want to ask this over there. (should be exactly the same)
May the force be with you - SoloWookie
solowookie.com
Shouldn't be too hard what engine/tranny are you replacing?
You only get one shot at life.
Better have a good aim!
Later Dudes
Joe
#20897 01/17/2002 12:59 PM
Mechainiac, I know that some caddy engines have rear sump pans and some not. This the only problem, as I see it. Find an engine with a rear sump, or swap the pan in the one you have if it's not rear sump, and drop it right in there. This engine is smaller that a bigblock chevy. And if a BBC fits there, the caddy will also fit. Of course there are those little items that makes our miserable engine swappers life a lot easier, just research before hand the exaust manifold models available, the engine can be set back a li'l more(ain't the distributor up front, just like in a Buick??) check to see if more than one option in the water pump inlet like in small mopars, etc...
Alexandre Garcia
#20898 01/18/2002 12:15 AM
V
V Offline
The Cadillac mounts require that the motor mounts be moved forward a couple of inches on the frame. You will also have to swap oil pans, an Eldorado pan or a 425 pan will work. That's pretty much it. It isn't difficult at all. Go to this message board, you'll get more help than you need: http://members.boardhost.com/BadCad/.
Also, if you need any parts for this swap, Al at MTS can set you up (oilpan, etc). He hosts the message board. There is a link at the top of the message board that will send you there.
Thank you guys for the info and leads,, I will check them out.
I wanted to revive this old topic out of curiosity mostly. I have been searching for info about Cadillac swaps and there is a lot out there. But so far I have found practically nothing on swaps with manual transmissions. I know way back there Caddy had stick-shift cars, and now there are some 5- and 6-speed cars, but for decades they were all automatics. I have a fantasy of putting a 500 Cadillac in my 50 3600 with an SM-420. Any takers? thanks :p
Professional Novice
Z
Z Offline
for a 472/500 you can use a pontiac/olds/buick bellhousing.there are no factory flywheels,but mts makes one.you have to drill the crankshaft for a pilot bearing. www.500cid.com
Thanks, Zenish for the link. smile
Professional Novice
Quote
Sounds like a better fantasy than any I ever had. eek
Fred
52 3600
69 C-10
