7 members (fonz8261, Rexville48, 1955 1 Series, Peggy M, mk72, Shardean, 55shaker),
60
Mod | | | Forums66 Topics128,022 Posts1,055,387 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 72 | Hi guys! Have posted this before, hope this time to figure something new out. My gas gauge does not work very often. I have rewired my ground many times. I believe I have a good ground. If I drive for a while some times it kicks in. Last time I drove, it came on after a couple starts and maybe 30 miles. Restarted truck next day and it worked. Started truck later that day, nothing. I have a brand new sending unit, think it is bad? Any ideas are greatly appreciated. | | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | My 61's gauge gets stuck sometimes, and then when I hit the dash right above the gauge it works again. I am not sure what that means but I think that I must have a loose wire or my gauge is gummed up inside. Oh well...another project.
Kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Jul 2005 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 72 | I do have new gauges. I do not have loose wires at the gauge. I did check that. | | | | | Joined: Mar 2005 Posts: 75 Member | | Member Joined: Mar 2005 Posts: 75 | t6ake the wire off of the gauge with the key on and touch it to the ground and if the gauge goes all the way full then your problem is not in the wires, what year truck is this on? | | |
