6 members (frogfarmer, Bill Hanlon, RoadsScholar, klhansen, Otto Skorzeny, UtahYork), 151 guests, and 1 robot.
Topics128,087
Posts1,055,974
Members48,430
#208573 05/27/2006 12:07 PM
Junior Member
Junior Member
I have one rear tail/stop light that is dimmer than the other,can anyone help with possible cure.This is on a '59 Apache Fleetside. Thank you, this is a great site.
#208574 05/27/2006 12:11 PM
Check for a bad ground or dirty bulb socket.
#208575 05/27/2006 12:20 PM
Junior Member
Junior Member
Thank you for the quick response Wrench Fetcher,my ground is on the frame on the passenger side,it is rusty,but tight.I guess I should remove and clean.
Thanks a bunch!
#208576 05/27/2006 8:32 PM
Hey Old School,
Had the same problem on my '49. I ran a ground from the battery to the engine, from the engine to the frame and from the cab to the engine. My brake lights will almost blind you now!
My truck: She may not be the prettiest girl at the dance, but she's all mine!
#208577 05/28/2006 12:34 AM
Something that happens frequently on the old trucks(and cars) with the metal socket and reflector is corrosion will form in the seam where the socket is crimped to the reflector. You can test for this by running a jumper from a good ground to the socket itself, if this brightens it then you can remove the tailight bucket and put a dot of brass on with half the dot on the socket and half on the reflector. Be careful because many of the old sockets are themselves brass so heat carefully. Good luck
Evan
#208578 05/28/2006 1:35 PM
Junior Member
Junior Member
Cleaned corrosion in tail lamp bucket,fixed me right up.Thank all of you for your help.Great advice!
