6 members (SmalltownTRKGuy, Otto Skorzeny, moparguy, Gdads51, dt235sd, 1 invisible), 76 guests, and 4 robots.
Topics128,094
Posts1,056,056
Members48,433
#208522 05/26/2006 7:20 PM
I was reading on the Jim Carter Web Site that 39 and 40 just had the glass and in 41 GM went to the metal frame around the glass. My 39 GMC has the metal frames. I thought they all had the frames. Now im confussed.
#208523 05/26/2006 9:00 PM
My 39 also has metal frames, so at least you know your not alone.
1939 GMC
1953 HD PANHEAD
1930 Chevy 3 window coupe
#208524 05/27/2006 2:00 AM
I
I Offline
My 40 has the metal frames
#208525 05/27/2006 2:45 AM
Apprentice
Apprentice
My 39 also has metal frames.
#208526 05/27/2006 3:02 PM
I had both a '39 and a '40 GMC with metal frames, and keylocks in the passenger door handle, so it's a safe bet they were original doors.
#208527 05/28/2006 2:34 PM
i haven't got to the point of taking my doors apart for weather strip and rattle stuff. 1939 chevy 3/4 T. at least the top edge of the door window glass does not have a metal edge. when i get home i will look closer at the glass. or maybe i don't under stand the question?
"It ain't a truck if you can't hose out the cab."
