| | | Forums66 Topics128,132 Posts1,056,388 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | I was reading on the Jim Carter Web Site that 39 and 40 just had the glass and in 41 GM went to the metal frame around the glass. My 39 GMC has the metal frames. I thought they all had the frames. Now im confussed. | | | | | Joined: Sep 2003 Posts: 66 New Guy | | New Guy Joined: Sep 2003 Posts: 66 | My 39 also has metal frames, so at least you know your not alone.
1939 GMC 1953 HD PANHEAD 1930 Chevy 3 window coupe
| | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | My 40 has the metal frames | | | | | Joined: Aug 2004 Posts: 21 Apprentice | | Apprentice Joined: Aug 2004 Posts: 21 | My 39 also has metal frames. | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | I had both a '39 and a '40 GMC with metal frames, and keylocks in the passenger door handle, so it's a safe bet they were original doors.
| | | | | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | i haven't got to the point of taking my doors apart for weather strip and rattle stuff. 1939 chevy 3/4 T. at least the top edge of the door window glass does not have a metal edge. when i get home i will look closer at the glass. or maybe i don't under stand the question?
"It ain't a truck if you can't hose out the cab."
