7 members (frogfarmer, klhansen, Otto Skorzeny, UtahYork, 1955 1 Series, greenie-reddy, dt235sd), 164 guests, and 1 robot.
Topics128,087
Posts1,055,974
Members48,430
Junior Member
Junior Member
I was informed that i would be getting my 1969 Ford Bronco on the road before I would be allowed to mess with my 1953 Chevy 3100.
I need to replace the radious arm bushings on the the Bronco. I believe that Lithium Grease it the best thing to use to keep them from moning and growning. I would like some imput on the matter.
Thanks :rolleyes:
Don't think poly need any lube. thats the beauty of them
I use a silicone lube on my bushings.This was reccomended by the bushing manufacturer. i get it from Napa, it's called Syl-Glyde. Good for rubber bushings too.
Bill Burmeister
i agree w/ gazim
it still can't hurt to put a smear on
but generally no greese is needed
Jim & Caroline
Junior Member
Junior Member
I thank everyone for their input. I never thought of silicone. It wouldn't break down when it gets wet either. I used to us it on my commercial dive gear and it worked great for that also. I might still have some lying around some place.
Thanks again!!
Former Workshop Owner
I believe that some petroleum based lubricants will soften certain types of plastic. I am not sure if that applys to Polyurethane.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
Junior Member
Junior Member
I read that on the HiPo threads John. If I remember right some oils and greases can mess them up. Thanks for the input.
Todd
