| | | Forums66 Topics128,014 Posts1,055,332 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#20813 10/07/2003 5:20 AM | Joined: Sep 2003 Posts: 55 Member | | Member Joined: Sep 2003 Posts: 55 | I'm putting a 250 in my 51 for a driver as a 250 does unleaded and the parts as well as the motor are penny wise. Any in put other than the bell houseing mount and 12 volt and radiator modifications? Thank you. The truck was a piece of rust whith a 51 some where in there 3 years ago so as far as ruining it, its already been there. and the repro parts aren't perfect. Its a driver with a stock frame and body. In other words I don't feel a 250 is a hack but a rebirth of some thing that could go back to the earth or find me. So have any of you done this? Way thank you!  O. The town of Sedro Wooley mamouth thanks you all as well. | | |
#20814 10/07/2003 5:37 AM | | Anonymous Unregistered | | Anonymous Unregistered | Use an aftermarket V8 tube cross member and go with a later model tranny and open drive rearend. The clutch linkage is an easy fab as is the new transmission cross member. I have seen this swap a couple of times. A guy name Rob Atkins with Split Window Restorations down here in Portland has a '51-ish set up this way and it is nice transplant. | | |
#20815 10/07/2003 5:46 AM | Joined: Sep 2003 Posts: 55 Member | | Member Joined: Sep 2003 Posts: 55 | Thank you ken. I talked to Buffalo who suggested a t5 and **** rear end. He's the stuff but I like the G.M. rear end. By the way, way cool C.O.E. If I could get one and keep my wife...well you know the story. O  | | |
