| | | Forums66 Topics128,014 Posts1,055,332 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 50 | I just bought a '59 big window long step for $300. The weird part is the two speed electric wipers on it. The motor is a Delco Rochester with stamped steel brackets and assembled with clutch head screws, strictly factory made. The strange part is this one has an electrical switch not the usual mechanical slider. It appears to be a worm drive and mounts sideways eith one arm above the motor and one below. It has straight crank arms and turns only one direction. Has anyone seen one of these? It could be a later GM retrofit or ???? Any information would be appreciated. Thanks :confused:
They named it Apache cause it has a patchy welded here and a patchy welded there.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I've never seen anything other than the same old factory wipers - someone may have replaced the switch later, not hard to do - get a shop manual and you'll find the electric wiper covered in it including pics of the internals - if it's anything else it's someones custom job Bill | | | | | Joined: Feb 2006 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 50 | Thanks for the quick reply. I hear what you're saying, but this looks way too engineered to be a one off. I will post some pics ifI get a chance. The motor has a cam and a relay box cast into the base. I just hope it works cause I have only vacuum otherwise.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | they're not too hard to find, and modern replacement units are available at all the vendors made for the application work well
Bill | | |
