5 members (gswbbc, Otto Skorzeny, Eisenholtz, klhansen, 1 invisible), 82 guests, and 2 robots.
Topics128,032
Posts1,055,521
Members48,425
#207701 05/13/2006 12:57 PM
Can I put a carb for a 250 on my 235????
Larry Bear
55.5 Chevy 3100 Panel
#207702 05/13/2006 9:33 PM
Riding in the Passing Lane
If the 250 carb is off a 67 on back (model B)it should fit with possibly some minor modifications depending on the year. 68 up used the Mono-jet. It could probably be made to work but would require some enginering.
1972 Chevy c10 Cheyenne Super
#207703 05/13/2006 11:10 PM
Carburetion specialist
For best results migrating O.E. carburetors:
Generally, an O.E. carburetor may be migrated to a similiar engine/transmission/vehicle with an engine displacement within 3 percent of the original engine.
3 percent of 250 CID is 7.5 CID. 250 CID - 7.5 CID is 242.5 CID. The 235 does not fall in the range.
This does NOT mean you cannot make the switch, but results may be less than desired.
Jon.
The Carburetor Shop
#207704 05/14/2006 11:45 AM
Thanks guys... came across this NOS carb (still in the box) and thought I'd check...
Larry Bear
#207705 05/15/2006 1:13 PM
heck if it,s cheap try it...doc
#207706 05/15/2006 5:45 PM
Doc - I would respectfully disagree. Rochester used components in this carburetor which are NOT compatible with modern fuel. Even if the N.O.S. carburetor is free, it will still require rebuilding (at least the accelerator pump, the fuel valve, and the gaskets will need replacing).
Jon.
The Carburetor Shop
#207707 05/15/2006 8:37 PM
I posted the question originally working from memory because I had misplaced the piece of paper with all of the specs on it... Actually, the NOS carb is for a 1955 265 which I understand will definately not work on my 235.
That's what I get for trying to bank on my memory (or lack thereof!)
If anyone's interested in this carb I can try and find out if it's still available... guy want's somewhere around $150....
AND I'm still looking for a NOS carb for my 235 (1960 engine)!
Larry Bear
#207708 05/15/2006 10:06 PM
Larry - give me a call during normal telephone hours.
Jon.
The Carburetor Shop
