3 members (Bucker, 3B, Snowman51), 94 guests, and 0 robots.
Topics128,157
Posts1,056,893
Members48,458
I have a quick basic question - at least I think it's basic, but I don't know the answer. :confused:
Can stainless steel and regular steel be welded together? :rolleyes:
Joe
Junior Member
Junior Member
Yes, it can be tig welded using 309 rod which is made to weld stainless to carbon steel. It can be welded with carbon or stainless stick rod. It can be mig welded with stainless or carbon wire. The only welding method that you would encounter problems using would be with an oxy/act torch.
Living the simple life ain't simple
OK - Thank you!
Here is the second part of the question - can stainless steel be chorme plated? :confused:
Joe wink
Absolutely
Keith
If it were easy they'd have grade schoolers doing it!
