| | | Forums66 Topics128,263 Posts1,058,348 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#20740 02/08/2004 8:36 PM | Joined: Sep 2002 Posts: 158 knuckle head | | knuckle head Joined: Sep 2002 Posts: 158 | I just replaced the clutch in my truck,put in a new bronze pilot bushing also. The question;does the bushing get a swab a grease, or is it the type needing no added lubrication. | | |
#20741 02/08/2004 10:42 PM | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | Rust Bucket,
Coat the inside of the bushing with wheel bearing or similar high temp grease. You want it lubed but you don't want grease oozing around the shaft and onto your new clutch.
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
#20742 02/09/2004 2:18 AM | Joined: Sep 2002 Posts: 158 knuckle head | | knuckle head Joined: Sep 2002 Posts: 158 | I looked at a Mopar service bulletin recomending gease on the bushing. But two clutch manafacturers say no to grease, one says oil only, the other says its an oilite bushing, add no oil.The bushing I installed is the Oilite bronze type. | | |
#20743 02/09/2004 3:13 AM | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | I need to do this on my 261 engine and have never tried this before. Two questions 1. What is the best way to remove the pilot bushing? and 2. Where did you guys order the pilot bushing from?
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
#20744 02/09/2004 4:27 AM | Joined: Nov 2003 Posts: 39 Junior Member | | Junior Member Joined: Nov 2003 Posts: 39 | The best thing to remove a pilot bushing with is Grease. Yep you got it. You will need a piece of rod about the same diameter as the input shaft. Steel, alum, brass all will do as long as it is a close fit in the pilot bushing. Then fill the pilot bushing with grease, as much as will go into the hole. Put the rod you have selected in the pilot bushing. there should be resistance and hit it with the hammer. The hydraulic pressure is like a piston in a brake caliper. It usually pops the bushing out. I usually get a clutch pack for fairly late model stuff, it comes with the clutch, pressure plate, throw out bearing and pilot bushing.
There is no mechanical problem so difficult that it can not be overcome by brute force and ignorance.
#20745 02/09/2004 1:10 PM | Joined: Nov 2000 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2000 Posts: 21 | Greese works good for removing the pilot bushing, the last time I removed a pilot bushing I used clay, the clay your kids play with. Worked as good, much easier to clean up. That hint was on this board some time ago.
1948 Chevy 5 window "6" powered
#20746 02/09/2004 2:14 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Cujo,the bushing is the same a a Chevy V-8, .592 inside , 1.094 outside, about .75 long.I've always been told to oil the bushing only, grease supposedly clogs the pores,but I don't know for sure. The grease or Playdough works just fine,some guys thread in a 3/8 pipe tap, attach it to a slide hammer. | | |
#20747 02/09/2004 7:51 PM | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | How come you guys never mention a pilot bearing instead of a pilot bushing? Both are available. _Scott
55 1st Chev.
#20748 02/10/2004 4:02 PM | Joined: May 2003 Posts: 111 Member | | Member Joined: May 2003 Posts: 111 | I used a slide hammer with an expanding hook. Two taps and it was out. Lucky for me, my Dad had the tool, so I didn't have to hunt it down and buy it ( Cheap is good, but free is for me!).
35 + years of rollin' steel!
