Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Sjm, Tyler Watts), 112 guests, and 2 robots.
Topics128,281
Posts1,058,464
Members48,490
#207371 05/08/2006 11:46 PM
I posted this questing once and even searched in the archives but could not find what I am looking for. I may have done the search incorrectly, but I tried. So what fluid can I use in the steering box. Sorry but I just don't know.
1946 1/2 ton
I'm not addicted I just don't know when to stop
#207372 05/09/2006 8:35 AM
If it's not power steering, use 90wt gear lube/oil.
KEEP ON TRUCKIN,MAMA... TRUCKIN TILL THE BREAK OF DAY... I SAID,KEEP ON TRUCKIN,MAMA... TRUCKIN MY BLUES AWAY...
#207373 05/09/2006 1:17 PM
Here's the post you're looking for: http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=011401
Mike Barnes
1950 GMC 1-ton pickup
#207374 05/09/2006 10:59 PM
Some of those posts say use grease. Probably a bad idea. 90wt is ok, but will probably leak out. I used Penrite, and it worked great. Not exactly cheap though. The other thing you will need is a genuine GM seal for the sector shaft. The rebuild kits come with a seal, but those are junk. Group # 6.855, part #07801626
