| | | Forums66 Topics128,036 Posts1,055,454 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 107 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 107 | I posted this questing once and even searched in the archives but could not find what I am looking for. I may have done the search incorrectly, but I tried. So what fluid can I use in the steering box. Sorry but I just don't know.
1946 1/2 ton I'm not addicted I just don't know when to stop
| | | | | Joined: Mar 2006 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 23 | If it's not power steering, use 90wt gear lube/oil.
KEEP ON TRUCKIN,MAMA... TRUCKIN TILL THE BREAK OF DAY... I SAID,KEEP ON TRUCKIN,MAMA... TRUCKIN MY BLUES AWAY...
| | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | Here's the post you're looking for: http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=011401
Mike Barnes 1950 GMC 1-ton pickup
| | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Some of those posts say use grease. Probably a bad idea. 90wt is ok, but will probably leak out. I used Penrite, and it worked great. Not exactly cheap though. The other thing you will need is a genuine GM seal for the sector shaft. The rebuild kits come with a seal, but those are junk. Group # 6.855, part #07801626 | | |
