| | | Forums66 Topics128,136 Posts1,056,427 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 43 Junior Member | | Junior Member Joined: Aug 2005 Posts: 43 | This is just FYI. After hunting for quite a while I found a hitch for my 1954 half ton. I checked on line with Reese, Hidden Hitch, Eaz Lift, U-Haul, Coleman and others with no luck. Then I found a Reese multi-fit at Auto Zone that I measured in the store and it looked like it would work. The thing comes with several bracket choices in the box and a bunch of spacers, bolts, and etc. I have about ten pounds of stuff I didn't use. It's a Class II which is probably more than I need. I mounted it to the frame and it sets behind the bumper aginst the bottom of the bracket for the plate light. It's between the spare tire and the bulb. I did have to drill half-inch holes in the frame. It's Reese 88001 and cost $125. Towed a six foot brush hog in the utility trailer and it worked fine. Just in case you're ever looking for a receiver hitch. Rich | | | | | Joined: Aug 2005 Posts: 157 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 157 | That's nice to know, Rich. Thank you. This is one of those little bits of info that will keep popping up when some one does a search for "trailer hitch". | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | thanks rich, i have been looking at that one for a long time wondering if it would work. now i know. the only differance is i have a rollpan on my 54. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
