2 members (walter74, klhansen), 117 guests, and 3 robots.
Topics128,062
Posts1,055,854
Members48,428
I've got a 235 with the foot starter. I had the starter professionally rebuilt and it works well most the time. I have converted to 12 volt. Problem is about 20% of the time the starter gear does not engage the flywheel gear before it starts spinning and I get a loud, embarrasing sound. I took the contactor switch off the top of the starter and slotted the holes some so that I could move it forward away from the lever in hopes that it would close the contact later in the starting sequence to help the problem but it still does it some.
Anybody had this problem?
Any suggestions?
Should I be pressing the start pedal slowly or jabbing it quickly? THANKS!
Rob Mathis
48 Half Ton with 235 & SM420
Got the same problem...Only happens when there are people around to hear it make noise..
Oh, absolutely! I failed to mention that! Only when people are around.
Rob Mathis
yeah sonds familiar to me. More folks arround = higher chance of noise.
My flywheel was worn out at a particular area. When the starter hits this area I got the sound.
Pressing the clutch and shifting around a bit moves the flywheel a bit where the theeth are better and it starts.
my 2 cent, Frank
Junior Member
Junior Member
could it have a newer ring gear on the flywheel? i think the newer 235 engines had a different tooth count on the ring gear than the older ones
jerry
