| | | Forums66 Topics128,059 Posts1,055,825 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#20728 05/27/2005 8:58 PM | Joined: Oct 2004 Posts: 19 New Guy | | New Guy Joined: Oct 2004 Posts: 19 | I've got a 235 with the foot starter. I had the starter professionally rebuilt and it works well most the time. I have converted to 12 volt. Problem is about 20% of the time the starter gear does not engage the flywheel gear before it starts spinning and I get a loud, embarrasing sound. I took the contactor switch off the top of the starter and slotted the holes some so that I could move it forward away from the lever in hopes that it would close the contact later in the starting sequence to help the problem but it still does it some. Anybody had this problem? Any suggestions? Should I be pressing the start pedal slowly or jabbing it quickly? THANKS!
Rob Mathis
48 Half Ton with 235 & SM420
#20729 05/27/2005 9:53 PM | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Got the same problem...Only happens when there are people around to hear it make noise.. | | |
#20730 05/27/2005 10:00 PM | Joined: Oct 2004 Posts: 19 New Guy | | New Guy Joined: Oct 2004 Posts: 19 | Oh, absolutely! I failed to mention that! Only when people are around.
Rob Mathis
#20731 05/29/2005 4:05 PM | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | yeah sonds familiar to me. More folks arround = higher chance of noise.
My flywheel was worn out at a particular area. When the starter hits this area I got the sound.
Pressing the clutch and shifting around a bit moves the flywheel a bit where the theeth are better and it starts.
my 2 cent, Frank | | |
#20732 05/30/2005 5:30 AM | Joined: Jan 2003 Posts: 35 Junior Member | | Junior Member Joined: Jan 2003 Posts: 35 | could it have a newer ring gear on the flywheel? i think the newer 235 engines had a different tooth count on the ring gear than the older ones
jerry | | |
