4 members (Hotrod Lincoln, Otto Skorzeny, TexasJim50, Gib70), 150 guests, and 3 robots.
Topics128,164
Posts1,056,977
Members48,458
Apprentice
Apprentice
I need to tighten up my manual steering box. It's on a 58 Apache. I've never done this before. I have a basic understanding of the procedure from my shop manual, but need to know two things: 1) are the wheels on the ground or is the front end on jack stands when I tighten the box, and 2) what tool do I use to loosen/tighten the Worm BearingAdjuster Lock Nut?
I'll round off that bolt head....just as soon as I'm done strippin' this screw!
Apprentice
Apprentice
Answered my own question.
OK, if anyone else needs to know you will need a 2 and 1/4" hex socket, to turn the Worm Bering Adjuster Lock Nut. You can get one at Sears....(God I love Sears)...Also, It does not matter what you do with the wheels being on the ground or not once you disconnect the sector shaft from the pitman arm. Of course if you jack up the truck you will have more room to work...but I'm skinny..Oh, ya you will need a pitman arm puller...I'm not sure how to put the pitman arm back on yet. I'll let you know when I fugure it out.
3B Offline
Hy Lucky Strike, once you have finished your adjustments center the steering box, then put the wheels in the straight ahead position, now reinstall the pitman arm. Hope that helps.
Apprentice
Apprentice
Thanks 3B I kinda thought I needed to do something like that. I obviously have not messed with a steering box before.
I was told by somone that I should plan on replacing the sector shaft bushings while I'm at it....I duno' maybe I should try to rebuild the box...or do you think I can get away with tightening it up and putting in new sector shaft berings? I even got the part number for the berings, which apparently you can still get at the Chevy parts counter.
