0 members (), 115 guests, and 1 robot.
Topics128,113
Posts1,056,619
Members48,450
Junior Member
Junior Member
Have '49 1 ton with original rear axle (maybe called an HO72?) I Plan to install a SB Chevy, use original SM420, change out center section, upgrade all brakes.
Is there a way to upgrade the rear brakes, change them over to bendix?
Frank
1949 Chevy 3800
1929 Chevy International
Check if the post-51(?) 3/4 and 1T axles have the same bolt pattern for the backing plates. If so, the brakes can be transplanted to your axle. Otherwise, get a post 51 3/4 or 1T axle. The 3/4 will have a 4.57 ratio, and might make for better highway driving. There are many posts and threads here about changing ratios on these trucks.
Good luck.
