3 members (Gray_Ghost, DadsFirstPickup, moparguy), 102 guests, and 1 robot.
Topics128,131
Posts1,056,722
Members48,454
I have a bent axle on my truck and am curious is it is worth trying to straighten it out or am I better off buying a new one.
Roger
http://www.flickr.com/photos/45469713@N00/?saved=1
Riding in the Passing Lane
A front axle can be straightened by an alignment shop. Rear axle should be replaced.
1972 Chevy c10 Cheyenne Super
I have heard of it being done, but you should be able to pick up a used but straight one pretty easily and cheaply if you shop around a bit.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
Z
Z Offline
what year truck?i have a 65-66? rear i'll give you.
Actually there is a local 4x4 shop around here that straightens drive axle housings. It can be done if you know what you are doing.
I suspect that by time you pay for the labor it might be cheaper to replace the axle.
Big over the road truck shops all are equipped to straighten axles. Combinations of heavy loads and rough roads cause axle headaches. Whether they would take on a 1/2 or 3/4 ton is anybodys guess. A local shop in the Dallas area has straightened one for me but it was at their convenience, the big rigs came first and that's OK since they earn someone a living.
Evan
I have a 78 trans am rear end under my 55.
I will probably go to a scrap yard to find one but I was just curious what you all might know.
Zenish thanks for the offer but my truck is a 1955.
Roger
