8 members (Peggy M, Donf, Otto Skorzeny, Wickedbass, Hawkman, NJC, GRNHydra, hdgeren),
83
Mod | | | Forums66 Topics128,023 Posts1,055,370 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#20708 05/25/2004 6:32 AM | Joined: Aug 2003 Posts: 5 Member | | Member Joined: Aug 2003 Posts: 5 | my 52 3speed on floor open driveshaft has a backward shift pattern-3rd is where reverse should be-1st is where 2nd should be-2nd is where is should be-is this hard to change to normal shift pattern? Its ok if I drive a lot but when I change from my other truck with normal H pattern I grind gears for awhile | | |
#20709 05/26/2004 2:16 AM | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | Do you have a aftermarket floor shifter or the original column shift?,it sounds like someone has flipped the arms comming out of the trans. All you will have to do is reverse the arms from the way they are now and the problem should be solved.  | | |
