2 members (WICruiser, tclederman), 41 guests, and 2 robots.
Topics128,035
Posts1,055,443
Members48,422
#207060 05/02/2006 4:56 PM
Junior Member
Junior Member
Does anyone know if factory 16" rims and tires from an 06 chevy 2500 will fit a 70 3/4 ton pu 4x4? In my local paper there's a set for 400.00--polished. They would look great but not sure if offsets the same or? Thanks, M
#207061 05/02/2006 9:43 PM
take a piece of paper to double check your pattern...
SEE:
Wheel pattern:
http://www.tirerack.com/wheels/tech/techpage.jsp?techid=92
offset wheel & bolt pattern:
http://www.earlywheel.com/choosing.html
Jim & Caroline
#207062 05/02/2006 10:18 PM
Riding in the Passing Lane
I believe the patterns are the same but the offset is way off.
1972 Chevy c10 Cheyenne Super
#207063 05/02/2006 11:55 PM
i think that you will find that the big three went to a metric pattern somewhere around 1999 to 2000 and they are not the same.
1951 1 Ton Completed
#207064 05/03/2006 1:33 AM
Junior Member
Junior Member
Thanks all for the info. I will definitely do more research before I buy. M
