0 members (),
102
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | One of my doors is now apart and I’m wondering if there are supposed to be some kind of wheels or rollers on the piece that runs in the track at the bottom of the window. This slide bar in the mechanism that runs in the tract to raise and lowet the window has two round all steel lugs but no rollers. | | | | | Joined: Mar 2005 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 144 | Inside mechaanism on my 46 is the same. I just put a little grease on them and they work great. Bob T | | | | | Joined: Jul 2005 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 70 | I had one on one window. When I looked at it, it reminded me of something I'd seen somewhere before. So at the hardware store I bought a nylon roller about 1" round, with a small ball bearing centre in it, theyr'e used around the home, riding the track rail on the bottom of sliding fly screen doors and mesh sliding security doors. It worked.
"After you skin yer knuckles, Mr Shifter ain't yer friend any more." 1942 Chevy 3/4 tonIn the Stovebolt GalleryPhoto Site1946 Chevy 5 window coupe/ute (new stray) 2000 Nissan Patrol 4x4 4.5l turbo diesel
| | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Thanks for the help guys. I think I'll pull the other door apart and see if the lugs or channel are badly worn. It it is I'll go with rollers if it is in good shape like the driver's side, I'll just go with grease. | | |
