3 members (Gray_Ghost, greenie-reddy, carbking), 55 guests, and 6 robots.
Topics128,021
Posts1,055,355
Members48,420
#206740 04/26/2006 10:16 PM
I have a ’58 235 with solid lifters. Is it possible to install hydraulic lifters in place of the solids? If so, what else must I do? Anything? Or will the rockers and pushrods work with the hydraulics?
Oh no!! This probably should have been posted in the "Engine/Driveline" section
Thruwurkin
Kennewick, WA
Half Ton Will Travel
God bless America...One nation under God
#206741 04/27/2006 12:04 AM
I'm pretty sure the 235 truck blocks were drilled
through for hydraulic lifters in 58' so there should be no problem with using them. It would be wise however to look for a hole in the lifter cavity to be certain. You'd want to use new pushrods anyway and the rockers are the same. I had no problem using a 55' block. I assume your going to also replace the camshaft.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#206742 04/27/2006 3:09 AM
My 62' 235 had hydrolics already in before the rebuild. Could have been a car engine in its previous life. Decided to leave them in. They were in super shape and only required a scosh of machining to flatten them. Haven't heard it run yet
though.
#206743 04/27/2006 11:38 PM
Just check to see that the block is cross-drilled for the hydraulic oiling passages. Not sure what year the truck blocks were available with them (we have a '56 that's not drilled) though. But, why do you want to go to hydraulic in the first place? On the '59 passenger-car engine I'm doing, it'll have solids.
#206744 04/28/2006 6:44 PM
Quote
I'm not going to go to hydraulics. I'm just curious.
Thruwurkin
Kennewick, WA
#206745 04/29/2006 4:06 AM
Junior Member
Junior Member
Rattletrap,
I believe the bottom of the lifter should be slightly convex so they will rotate when moving
up and down in the lifter bore.
Arnie
#206746 05/01/2006 2:46 PM
A '58 235 would have had hydraulic lifters. Are you sure it isn't an older engine?
#206747 05/01/2006 3:24 PM
I ran the numbers on the block it is a '58 truck engine and it has solid lifters. The engine came out of a 1-1/2 ton orchard truck on on a farm near here.
I totally agree with Arnie258 in that the bottom of the lifter must be convex so that they will rotate.
RF, where do I look to see if the block is cross drilled? I don't have a clue.
Thruwurkin
Kennewick, WA
#206748 05/01/2006 5:27 PM
Inside the lifter bores, you'll see the small oil galleys the length of the block.
#206749 05/01/2006 5:28 PM
As I Remember,The oil passage is drilled thru the side of the Lifter Bore,From front to back.
#206750 05/11/2006 12:47 AM
Hydraulic lifters were a mid-year change in '56,
but the way I understand it trucks went back to
solids in late '56 to at least '59/60. I could
see a hydraulic cam engine finding it's way into
a light truck if production was behind though.
Bill Burmeister
#206751 05/22/2006 7:37 PM
If that engine came from a '58 1 1/2 ton, it may be a 261. Does it have "captains bars" just above the starter? You can't really tell the difference externally between the 235 and the 261 except for the captains bars - and they are true most of the time. The 261 is a much stronger engine, you will be lucky is that is the case.
#206752 05/22/2006 7:59 PM
Quote
LOL...Murphy's Law. No Capt Bars. By the way, do you know that Murphy is a female?
Thruwurkin (Duckin' and runnin')
Kennewick, WA
