3 members (delky, Hotrod Lincoln, Rich'sToys), 78 guests, and 0 robots.
Topics128,049
Posts1,055,740
#206624 04/24/2006 8:45 PM
I want to exchange my 16" stock rims for 15" X 7" steal rims but keep my stock hub caps. I have a 46 chevy 1/2 ton with 6 lug. Any ideas?
#206625 04/25/2006 4:36 PM
Not much response here, you'll have to do some rim shopping on the net as I know nothing about it either. Try hotrod shops and of course hot link
Good luck
Richard
#206626 04/25/2006 4:53 PM
We won't help ya "steal" wheels, John but if it's "steel" wheels, here's another link -
Stockton Wheel Service
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
#206627 04/25/2006 5:40 PM
Thanks for the info also, I will work on my on my speling!
#206628 04/25/2006 10:03 PM
YOu can probably find some 15x7 6 lug steel rims at the junk yard that'll take more modern hubcaps. I'm not sure if GM ever made a 15x7 6 lug rim that'll take clip style hubcaps.
The problem is going to be finding some that take your stock hubcaps. Your stock hubcaps probably use the clips, which require a certain pattern on the middle of the rim. The more common and later rims have a hubcap that goes right on the rim, sometimes called 'baby moons.' I would bet you can find baby moons that look like the original hubcaps and fit on the more modern rim. That's what I did.
Modern rims in the 15x7 six lug variety are $10 apiece, if you pull them yourself.
#206629 04/25/2006 10:44 PM
Here's an article from Smokey Culver on installing clips on wheels that you might find useful too, John
Installing Hubcap Clips On 8-Lug Rims
Larry Kephart
Boca Raton, Florida
#206630 04/26/2006 11:45 PM
jeep 6 lug
Jim & Caroline
#206631 04/27/2006 2:05 AM
jeep 6 lug?
#206632 04/27/2006 4:26 AM
Use stock 15" rims off a 55 to 59 or so half ton, will take your original hub caps just fine.
1946 1/2-Ton Chevy
#206633 04/27/2006 4:36 AM
That JiMerit - only 397 post on this site, but the guy ALWAYS has good information on every post!!
Thank you, JiM!
Joe wink
