| | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 172 | yea so the wipers on my truck suck. the guy i bought the truck from threw in some "new ones" but they arent worth crap. i think it might just be the arms that hold the wipers on. they basically just skim over most of the water on the windshield or spread and smear it across the rest of the windshield. any ideas? thanks in advance.
patrick | | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | The springs in your arms must be too weak to force the rubber onto the glass.
Mike Barnes 1950 GMC 1-ton pickup
| | | | | Joined: Apr 2006 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 172 | yea thats what im thinkin. ill probably just invest in a whole new wiper system. btw is there supposed to be a switch for the washer fluid or did they not have washer fluid back in the day? | | | | | Joined: Feb 2006 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 67 | Hi-jcking a thread again, but one of the things that doesn't wprk on my '66 is the washer pump. There is a plunger built into the wiper switch, but it doesn't appear to do anything. The washer motor appears to be fitted to the lower rear of the wipesr motoe (under the dash). Is it supposed to be the pump up type? I might just bin it in favour of a electic one. | | | | | Joined: Nov 2004 Posts: 2,399 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,399 | The '63 that I owned many years ago did not have a washer sprayer. If it was available, it most likely would have been an option. If I remember correctly, the windshield on a '63 is the wrap around type, and would probably require a very flexible wiper arm to wipe effectively. It could be possible that someone replaced the arms years ago with arms that do not match the windshield well.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Apr 2006 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 172 | well the wipers only go across the front of the windshield which is fine but they dont get the water off effectively enough. im pretty sure the springs just arent strong enough on the arms and i think the wiper blades i just put on mustve been sitting around for a while when the previous owner had them becuase they dont seem new but maybe when i install new arms theyll work better. thanks everyone. | | |
